I am looking at buying an LC-1 in additional to my PLX sm-afr. One question that I have deals with proper grounding. I use a lighter adapter for a power source and also to ground for my PLX SM-AFR.
For those using the WB as mobile tuning devices, what are you doing for proper grounding? Are you running a seperate wire to the battery or is there a better/easier way to obtain a proper ground?
