Is there any way to scale displacement, injector size and MAF table to allow you get more out of the stock meter I am going to end up in the 650 RWHP with a blow through setup on a 2002 Camaro. Thanks.
After doing several 750+ rwhp blown LS1s, I have given up trying to play with the MAFs and have gravitated to using the Custom OS v3 and Speed Density. Save yourself the headaches and dump the MAF. After spending 4+ years tuning cars with LS1Edit and putting up with the headaches of the MAFs, I don't regret going SD on blown cars one bit.
I think you will find by incorporating the 2 bar MAP and the features within the custom OS, you will have a much more responsive and better behaved vehicle.
