i have stft problems seem to try and deduct fuel past 30% wont idle etc
i thought about it an came up with maybe the source of the problem
*** my injectors*** thay wont pulse width lower than 2.199 if they cant deliver a small enough pulse, when thay do open -only deliver a 2.0 shot
few signs of that is very lean deacceleration and stft try to steady idle but cant go lean enough (small pulse) so over corrects
i have the 42lbs ford (green dragons) i have entered correct voltages and minpw and flow rate but ill try to increase the flow rate by 10% at a time in order to try and get a min pulse width lower than 2.0 and small pulse adders make the values into the - NEG,S need some input?
