Results 1 to 6 of 6
Thread: Throttle body bump stop
    Apr 2010
    Default Throttle body bump stop
    Hi all, sorry if this is irrelevant but I wanted to know if there is an adverse affect to this.
    m sure you have all heard that LS1 throttle bodies dont open to 90 deg and that people trim the bump stops. Im curious to the side effects ???
    In data logging the scan tool knows the throttle is 100% open, wouldn't the bump stop mod push it over the edge???
    Nov 2006
    Do you see less that 100%?
    I milled mine slightly and still see no ill effects but it probably wasn't necessary.
    LC-1 WBO2
    Junior Member Frost's Avatar
    Nov 2009
    Be careful though... if WOT VDC goes over something like 4.75V, you will set a TPS code (high voltage) and the car will fall right out of PE at WOT (not good!).
    Steve Williams
    Apr 2010
    Quote Originally Posted by Frost View Post
    Good info Frost
    Apr 2010
    yeah thats what I heard about the voltage thing, but my scan from a drive shows 100% throttle at WOT, so the PCM knows it at full so if i trim it a bit, it doent change this as it cant go above 100% but does physically allow the throttle to open a bit more at 90 deg rather than 85* as long as it doesnt go past 4.75 V
    Nov 2006
    You might need to mill of a good bit to get exactly 90°
    I removed 0.065" (1.65mm)
    LC-1 WBO2
  1. Throttle body set screw
    By 99STEPSIDE in forum Gen III V8 Specific
    Last Post: August 8th, 2009, 05:30 AM
  2. Throttle Body Area Scalar
    By finishline in forum Gen IV V8 Specific
    Last Post: August 24th, 2007, 01:05 PM
  3. How is a larger throttle body accounted for?
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: October 14th, 2005, 02:00 AM
  4. Paul, Throttle body scaler.
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: August 22nd, 2005, 02:28 PM
  5. Electronic throttle control conversion for the F-Body?
    By leres in forum General (Petrol, Gas, Ethanol)
    Last Post: July 23rd, 2005, 07:02 AM
