Results 1 to 10 of 11
Thread: Serial AFR Reads 25.00
    Feb 2005
    Default Serial AFR Reads 25.00
    Hey all,
    im having a little trouble with bbl, im using a LM2 with a serial connection, the V2 displays the AFR perfectly, and works perfectly when used as a pass through, however when in bbl mode the AFR reads a flat 25.00 with no movement at all.
    What could be wrong?
    Hi Agro,
    Do you have these settings, see attached #1 [with AFR as one of the Data Layout]...?
    Do you have the setting Automatically select ALL external digital (serial) PIDs (see attached #2)...?
    Are you BBL logging the pid WO2AFR1...?
    From the V2 LCD, go Scan Tool->Data Logging->Display WO2, does the AFR display there...?
Name:	S&T - Device Setings - Serial IO.png
ID:	7779   Click image for larger version.
Name:	S&T - Device Settings - BBL.png
    Nov 2006
    LC-1 WBO2
    Feb 2005
    Thanks for the reply,
    my setting are identical to what you have.
    The afr shows fine when Scan Tool->Data Logging->Display WO2
    I have manually entered the WO2AFR1 in the pid settings 'CALC' omitted as well.
    Hi Agro,
    Feb 2005
    Thanks for that, i did run through that procedure still no go.
    Nov 2006
    Are you logging all the serial PIDs needed?
    LC-1 WBO2
    Feb 2005
    Quote Originally Posted by mr.prick View Post
    I'm pretty sure I am
    do you mind giving me a list so I can compare?
    Nov 2006
    Ext.wo2afr1
    ext.wo2eqr1
    ext.wo2lam1
    ext.wo2st1
    LC-1 WBO2
    Feb 2005
    Ext.wo2afr1
    ext.wo2eqr1
    ext.wo2lam1
    ext.wo2st1
    I have similar pids
    still not working
    any other suggestions?
    Nov 2006
    And the same settings programmed into the V2 as Joecar's post?
    It maybe that the LM-2 is not yet supported.
    Post a log, it could be a bug in the firmware.
    There was a firmware that failed to display serial EQ but AFR and Lambda worked.
    LC-1 WBO2
  1. VE log reads 0.00
    By nchristian in forum Gen III V8 Specific
    Last Post: March 12th, 2009, 06:01 PM
  2. DIC reads "clean exhaust filter" DPF DELETED
    By ptownbacker5 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 28th, 2008, 05:10 PM
  3. OBD to serial to USB
    By kjhansen in forum EFILive V4
    Last Post: April 6th, 2008, 02:20 AM
  4. LTFT Cell reads -100% after clearing!
    By Ken G in forum General
    Last Post: July 17th, 2006, 09:44 PM
  5. 02 sensor reads silly????
    By AGRO in forum General (Petrol, Gas, Ethanol)
    Last Post: July 24th, 2005, 06:13 AM
