Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: RR problems
  1. #11
    Nov 2008
    Thanks Paul, that worked!
    But when I try to read the tune back out after flashing a 512K operating system/cal, I get a message that says "unknown bin file format". Is there a way to completely wipe out whats stored on the RR? I took off the battery in hopes of maybe clearing it....
    Just to check, I did the same with a 1MB tune file and it worked perfectly.
  2. #12
    Can you send me the 512K *.tun file that you attempted to flash into the RR?
    Send to paul@efilive.com
  3. #13
    Nov 2008
    Email sent...
  4. #14
    Sorry, can you also send me the BadFileFormat.tun file that EFILive will automatically save when it gives you the bad bin file format error.
  5. #15
    Ok, I have both files thanks. I can see the problem but I can't tell what caused it yet. I will need to talk to Moates about why it is failing and what we can do about it.
    Once last thing, does the vehicle start/run once you have programmed the 512K file into it? Based on what I can see I would expect that it would not, but I just need your confirmation.
  6. #16
    Nov 2008
    Paul,
    I haven't had a chance to actually hook this up to my vehicle yet. I'm running it on a bench-top harness at the moment, but I also suspect that it will not run the engine if I tried.
    Thanks for all your help!
  7. #17
    Actually after looking through the code, I think it will work and I think it will start and run your vehicle. Its worth trying at some stage.
    I am confident that if you hold the Ctrl+Shift when clicking on the "read" toolbar icon, the RR it will read out the data correctly. Let me know if that works.
  8. #18
    Nov 2008
    Oh really? That would be nice.
    I tried a full flash and read again, holding Ctrl+Shift and I'm still getting that unknown bin file format when I try to read the file back out.
  9. #19
    My mistake, the Ctrl+Shift won't allow you to read out the PCM.
    I'll wait to hear from Craig. Then I can make a decision on whether to not to implement the Ctrl+Shift option on the read as well.
    Meanwhile, I'll send you a test version with the Ctrl+Shift implemented on the read to determine if it will read out the 512K data correctly.
  10. #20
    Lifetime Member N0DIH's Avatar
    Jan 2006
    The RR emulates the 28F800 and 28F400, and IIRC the 28F200 flash IC's.
    I do not believe it emulates the 28F640, which has a slightly different pinout. But I don't think anyone ever used it in a PCM.... So it is a don't care. (more of my useless info...)
    I owned a Ford once, ONCE.......
  1. Help problems......
    By VACARELLAB in forum Duramax LB7
    Last Post: April 14th, 2009, 12:16 AM
  2. V2 problems
    By GAMEOVER in forum FlashScan V2
    Last Post: January 17th, 2009, 01:05 PM
  3. 2 problems
    By 1fastgto in forum Gen IV V8 Specific
    Last Post: December 26th, 2008, 05:27 AM
  4. Serious problems again - please help
    By Boost in forum Gen III V8 Specific
    Last Post: September 10th, 2007, 12:12 PM
  5. lc1 problems
    By woody69 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 07:39 AM
