Yep, multiple tuning experiments have proven it. I have played with VE and MAF calibrations and the only thing that changes is the LTFT's. No matter what I do, the logged AFR stays the same. I have gone from wildly negative to wildly positive LTFT's by altering the VE and MAF tables. But logged AFR stays around 15:1 while commanded is 14:63.
I don't really mind as I'm not running cats and being a little bit lean isn't going to hurt anything. But the net effects are that PE and lean cruise are off, so that I have to compensate by commanding richer AFR's than actual.
I thought that I had jacked my VE and MAF tables both so far out of whack that they were finding equilibrium at 15:1. But that theory didn't test out.
So I'm left with two theories: either the .cax files corrupted my tune so it wants to go lean, even when not commanded (unlikely), or that ethanol in the gas misleads the O2's regarding stoich.
Any opinions?
