Results 1 to 3 of 3
Thread: LBZ/LMM combined operating system
    Apr 2010
    Default LBZ/LMM combined operating system
    Hey all,
    I am involved in doing the electrics on duramax engine conversions. Problem I am having is when using the LMM engine and allsion transmissions is that there is no input/output on the ECM for tacho and cruise control, Its all done via CAN-bus
    We have looked into running the LBZ operating system and modifiying the harness to suit, However the problem is that the allison trans behind the LBZ has a torque converter speed sensor, LBZ does not.
    So what I would like to know is can we modify one of the operating systems to work. either change the LMM system to use analogue inputs for cruise/tacho rather than CAN, Or modify the LBZ system to run without the torque converter sensor.
    At this stage we are looking at fitting the extra sensor into the later model gearboxes, but if we can sort it via software would be alot easier.
    Also does anyone know if the LBZ and LMM air flow meters run the same calibration?
    Steve
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    Probably easiest right now to just swap to LBZ stuff and swap to an LBZ allison bellhousing that has the input speed sensor.
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Well, I'm not sure on the CAN messages, it's not really an area we ever need to dive in to, but with the airflow meters they are different. The LBZ uses a voltage output, the LMM is frequency.
  1. 09 lmm operating system
    By 07.5duramax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 11th, 2009, 12:59 PM
  2. 02 operating system?
    By THEFERMANATOR in forum Allison 5 & 6 Speed
    Last Post: October 25th, 2009, 12:58 PM
  3. wrong operating system?
    By HighPSI in forum E37, E38 & E67 PFI ECM's
    Last Post: March 2nd, 2008, 02:08 PM
  4. Going from 00 to 02 operating system
    By lastcall190 in forum Gen III V8 Specific
    Last Post: November 12th, 2007, 04:50 PM
  5. operating system
    By ls1transam346 in forum Gen III V8 Specific
    Last Post: February 22nd, 2007, 11:49 AM
