Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Lingenfelter TRG-001 58x to 24x Conversion Module
Hybrid View
    Aug 2008
    Question Lingenfelter TRG-001 58x to 24x Conversion Module
    Anybody on this site use it/recommend it... Have always wanted to try it out but kinda reluctant...IDK...
    Any problems? Pro's-Con's
    On the Lingenfelter site under description, it says it's pretty much straight forward plug-n-play. Just want a little more info of someone who's used it.
    FLASHSCAN V2 & AUTOCAL
    Jan 2006
    Yeah I have used it since it came out. Its really plug in play, you wont even know its there. I have put several 08 LS2's in camaro's and trucks with no problems. It sure beats changing the relector wheel like before. It sucked tearing down a new motor just to change that.
    If only they made a 24x to 58x box life would be awesome.
    Senior Member exploder's Avatar
    Aug 2008
    We have used several. I have had several malfunction. Were batting about .700 as of now.
    03 z06 auto
    ver7.5.5 custom OS5
    415 ci
    239/255 .624 lift LSr grind
    16psi
    Meth injection
    PLX WB02
    Aug 2008
    Quote Originally Posted by exploder View Post
    That's not good!
    Yeah, I'm trying to get an idea of what to expect, I mean, nothing's perfect...
    For the price that Lingenfelter sell's them, it sure beats changing out crank/cam reluctor wheel's.
    Aug 2008
    we have been using them since they came out and they have gone through several revisions. i don't want to make them sound like crap because they arent.
    03 z06 auto
    ver7.5.5 custom OS5
    415 ci
    16psi
    Meth injection
    PLX WB02
    Dec 2007
    Quote Originally Posted by GAMEOVER View Post
    That's not good!
    Decided not to go near them until after they had done a summer in 105F+ ambient heat. Some didnt even get to summer. 0.700 sounds about right.
    Aug 2008
    Alrighty, thanks for the info
    Jan 2006
    Yeah, I have a few act up but they were all on trucks. Lingenfelter has been really great to deal with and stands behind there work. They think its a heat issue that causes some to mess up.
    Feb 2006
    there is a thread on ls1.com.au with issuies of few of us aussies have had with them, it appears that if you mount them in the engine bay or anywhere that gets hot then a thermal protection kicks in and they stop working.
    normally have to wet it down to start up again.
    those of us who had problems just extended the wiring back into the cabin and havent had a problem since.
  1. Switching DSP5 tunes with V2 module
    By kdawg62 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 4th, 2010, 02:18 PM
  2. DBW pedal and TAC module differences
    By DURAtotheMAX in forum Gen III V8 Specific
    Last Post: September 17th, 2009, 06:09 PM
  3. New PID for Lingenfelter launch controller...
    Last Post: October 28th, 2008, 11:55 PM
  4. T43 DTC P0602 - Control Module not Programmed
    By gmh308 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: June 2nd, 2008, 08:58 PM
  5. Module Licensing question
    By Cougar281 in forum Purchase and Shipping
    Last Post: August 28th, 2006, 02:59 PM
