Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: help finding efilive explorer
    Senior Member restless@westnet.com.au's Avatar
    Aug 2008
    Default help finding efilive explorer
    i have lost efilive explorer from my windows start up ??
    i have reloaded efilive 5.7 latest ver but it is still not there ??
    im not very good with a pc and have just got a v2
    to start logging my e38 any help would be appreciated
    thanks
    Oct 2004
    EFILive Explorer is part of the version 8 software; so you need to have version 8.1.2 Build 94 installed.
    Then EFILive Explorer can be found in your Start menu (Programs\EFILive\V8\EFILive Explorer).
    Andrew
    EFILive Crew
    Aug 2008
    Quote Originally Posted by Tordne View Post
    ok got it thanks
    Aug 2008
    thanks
    now i cant seam to get the v2 to work anymore
    when im in efilive control panel f6 FIRMWARE
    with the v2 connected it says boot block OK in green v2 bootblock ver 2.06.03
    and the firmware ver is OK ver2.06.34
    but when i try to use it it says options.txt not found it was working OK with the old ver
    so how do i activate it with the new ver boot block and firmware
    thanks
    Hi Restless, welcome to the forum...
    Connect V2 to PS, start Scan&Tune (S&T) program, goto F5:Black Box Settings,
    and press the Program button (see the Program button at the bottom of attached pic).
    Doing that will get Options.txt copied to your V2.
Name:	S&T - Black Box Settings - Scan Settings.png
    Aug 2008
    thanks for that
    it started to load at 84% and then said
    ERROR$:0194 WRITE FAILURE ??
    Quote Originally Posted by restless@westnet.com.au View Post
    thanks for that
    Did you Format the Config space...?
    Exit S&T, then...
    Start EFILive Exlporer (EE), goto F9:Config Files, press Format Config.
    When the format is finished, exit EE and go back into S&T, goto F5:Black Box Settings and try the Program button again.
    I made Tech Support aware of this.
    So you got build 94, and have flashed 2.6.34 into your V2...?
    Oct 2004
    I think as Joe suggests you will be best to format the config and data filesystems. This is especially true if the firmware you have now updated from was quite old.
    Andrew
    EFILive Crew
    Aug 2008
    NO
    i didn't con-fig the space
    i have done that now and it it is loading the pid list of e38/t42
    how many pids can i load will it take 100% program
    or is it best to have as few as possible
    i have been having trouble with BBL logging going bad after about 10min after starting to log with the old version trying to log on to the lap top is hopeless as the graph takes about 5min to go across the screen it was OK when Steve ostrack first set it up but went bad soon after
    any ideas on what could be the problem i can shoot you a page shot if you like of what it looks like
    thanks for your help so far its very much appreciated i can tell you
  1. EFILive Explorer, Date/Time
    By Biodiesel66 in forum FlashScan V2 BB Logging
    Last Post: June 7th, 2010, 02:51 PM
  2. need help finding a laptop!
    By 07.5duramax in forum FlashScan V2
    Last Post: January 4th, 2009, 09:26 AM
  3. EFILive Explorer (Not Responding)
    By Naf in forum FlashScan V2
    Last Post: December 14th, 2008, 09:54 PM
  4. Vista and EFILive Explorer $0024
    By Black02SS in forum FlashScan V2 BB Logging
    Last Post: April 12th, 2008, 09:27 AM
