Results 1 to 7 of 7
Thread: EFILIVE conflicting with BANKS PDA...?
    New Member BJJ-DURAMAX's Avatar
    Apr 2010
    Default EFILIVE conflicting with BANKS PDA...?
    I e-mailed this to Nick at DURAMAXTUNER.COM but I also wanted to see what some of you might be thinking
    I did the EGR block , but I am still getting a 1-2 second delay on acceleration from a stop. On level 4 , I haven't tried other levels . If I give her 1/2 or more throttle she's fine , it's when I ease into it , it feels like I am getting no fuel...then it kicks in.....? Also , in my street tune , setting 4 , when I am NOT at W.O.T. , it feels like I am getting a de-fuel between shifts. I tried playing with my co-pilot putting it on different levels but had no change. Did all my settings get the de-fueling removed , some , none ? Even though I am just using my Banks PDA for guages , will it possibly be conflicting with the demands of my ecm/tcm ? On all the levels with the Banks , de-fueling is engauged to protect a stock tranny...could my Banks & EFILIVE be trying to counter each other ? I haven't removed the Banks yet to see if this might be an issue..only because I am afraid that it is an issue and now I will need to drop another
    $ 300.00 for new gauges.
    Other than these minor issues I am extreamly pleased with what Nick has done for my truck...my wife even had some fun with it , smokin' a ricer on the way to Wally World...now she wants to drive it...
    __________________
    '06 LBZ-CC-LB-DUALLY
    ATS STAGE II-CO-PILOT..HUGE THANKS TO JASON @ ATS
    EGR & REZO BLOCKED
    FASS 150
    4" T-BACK-NO KITTY-NO MUFF
    EFILIVE PRE-TUNED ECM/TCM-DSP-5 by NICK @ DURAMAXTUNER
    HARD WORK BEATS TALENT WHEN TALENT REFUSES TO WORK HARD
    **COLORADO BJJ**
    If you're just using the Banks setup for guages, I doubt there's a conflict. But Im not well-versed in Dmax stuff either. The potential is there though, electronics can be weird sometimes.
    Unplug the Banks and see what happens.
    Jan 2008
    I have made a custom OBD port to the passenger side of my truck and if i have EFI and my bullydog monitor plugged in at the same time EFI freaks out on a flash or even just a scan.
    Lifetime Member LBZoom's Avatar
    Jun 2008
    As far as the de-fuel between shifts at part throttle, there's not much you can do about that on the 2006 and later trucks. The trans and the ECM don't have a de-fuel adjustment for the diesel motor, just the 8.1 apparently. I shortened my shift times in small increments and it seemed to help the driveability a lot.
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
    I can't say for sure on all these products, but too many of them do not behave correctly when on the comms bus, some even ignore silence commands (very big no, no).
    Most of these monitor devices will be using scanning functions, you simply can't have two scantools on the bus at the same time.
    Jan 2008
    My thoughts exactly
  1. Banks iQ & EFI Live ????
    By Spuco in forum FlashScan V2
    Last Post: January 2nd, 2010, 01:16 AM
  2. EFILive and Banks Ottomind6
    By Schweinmesser in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 19th, 2008, 08:24 AM
  3. conflicting flashscan license stuff
    By BROKE in forum FlashScan V1
    Last Post: May 28th, 2008, 02:12 AM
  4. LTFT's Banks different
    By heavyfoot in forum General (Petrol, Gas, Ethanol)
    Last Post: August 26th, 2006, 11:48 AM
  5. Conflicting info on idle air flow
    By johnsZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 23rd, 2006, 02:33 AM
