Hello,
I hope I chose the correct category to place my post.
Without all the technical terms and abbreviations that I don''t know, is it possible to copy a 2010 camaro L99 V8 A6 computer and run either computer at any given time.
Another words have two computers and swap them back and forth? One with the stock tune, and one with another tune, to play with, or other tweaks??
If so will the car or the computer tell on you ? Will it throw codes? Will it say hey I've gone 1000 miles since the the last time I was plugged in something must be wrong ??
Is the ECU checking in with the odometer or is the odometer on the ECU??
If possible what's the process? And how much does a new 2010 camaro computer go for right now?
What is the computer part number or spec number ? (is there more than one part to it?) E38??
What software do I need to do it ??
Any links to the parts or software??
I just want to play with stuff. My car is 100% stock. I like to tinker and learn stuff. I'd like to turn off the AFM and play with the cooling fans, shift points, tune it, ect.. But leave it stock.
