Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Lc1 wrong readings.
  1. #11
    Nov 2006
    High LTFTs + improper VE & MAF = overly rich PE
    Try leaning out {B3618} to 1.176 and get LTFTs as close to 0% as possible
    You can reduce {B6203} to lessen the amount of KR, 25%-30% or so.
    KR is high even tho EQ is really rich.
    Cold start seemed overly rich too IMO.
    LC-1 WBO2
  2. #12
    Sep 2007
    I understand that I have a job to do with my tune, and have done the suggested change already. When I look at my last log it seems that the wideband is not as bad as I thought. May be the new controller was a good investment at all? Can someone that is used to look at log files see if these values from my wideband look normal? Or is the tune so way out that it is impossible to tell.
  3. #13
    Nov 2006
    Serial WBO2 is as good as it gets, either believe it or get a different brand WBO2.
    Be aware that serial AFR is based on the the fuel type in LM Programmer.
    http://forum.efilive.com/showpost.ph...0&postcount=11
    Something else to think about:
    Commanded AFR ≠ {B3601}
    LC-1 WBO2
  4. #14
    Log serial lambda or serial eqr, and do the conversion to AFR in the scantool (calc_pids.txt).
  1. What are your MAP readings?
    By TFZ_Z06 in forum Gen III V8 Specific
    Last Post: April 19th, 2010, 08:48 PM
  2. Torque / HP Readings
    By Duramax 6.6L in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 9th, 2009, 03:54 AM
  3. Please Help Readings Gone Crazy
    By nm2769 in forum Black Box Logging
    Last Post: May 21st, 2008, 05:38 AM
  4. Can you smooth out the AFR readings in FS?
    By Redline Motorsports in forum General
    Last Post: October 14th, 2006, 02:27 PM
  5. AFR readings low through EFI
    By Chalky in forum General
    Last Post: May 18th, 2006, 03:24 PM
