Originally Posted by
maudyZ28
OK,
after a run at the strip I reverted back to my stock PE vs rpm of 11.7 all over, previously I commanded 12.6 but it started to knock a bit at the top end of the revs so it was leaning out or timing was too advanced.
Im going to do more logging and a VE after my headers but wanted to get a bit of theory straight, which would be best vs stock timing and fuel at PE
1: PE vs RPM to richen from 12.6 to 12.2 and leave stock timing (still rich)
2: PE vs RPM to be 12.6 across the board and reduce timing from 4000 rpm by 2 deg
3: PE vs RPM to go like 13.2 to 12.8 and run 2-3 deg less timing everywhere or similar to a LS6 Z06 spark table
Basically from what I understand, the idea mix is 12.8-12.6 afr, and then you advance timing to suite (if i had a dyno). But the stock trim runs 11.7 and like 27.5-28 deg at WOT @ 4000 rpm (ish) is this just to make the over rich mixture burn more completely as there is more time for it to burn, but actually doesn't yield any power due to it been overly rich. SO I would get more power from a leaner mix closer to 12.6 with less than stock timing?
