Results 1 to 5 of 5
Thread: What is Pattern A & Pattern B on the 2010 Camaro 6L80 Tranny Tune??
    Apr 2010
    Default What is Pattern A & Pattern B on the 2010 Camaro 6L80 Tranny Tune??
    There are various folders in the shift control area of the tune & software.
    What is Pattern A & Pattern B on the 2010 Camaro 6L80 Tranny Tune using EFI Live??
    Is one when "D" is selected and the other when "S" is selected?
    Pattern A would typically be "Normal" mode, Pattern B would be sport or power mode.
    Apr 2010
    Default Besides pattern A & B
    Hi,
    Besides pattern A & B, there is a normal shift speeds folder and a hot shift speeds folder.
    When do therse come into play, and what are they used for ?
    Dec 2007
    Quote Originally Posted by 2010 Bumblebee View Post
    Hi,
    Typically 3 different shift modes. Normal/A/B.
    A could be sport/manual as GMPX mentioned, B tow/haul. Depends on the platform.
    Hot is for when the trans fluid has reached its max and cool down shift strategy is required.
    Apr 2008
    good info....
    Regards,
    Odd Boy
  1. Shift pattern selection
    By PSWired in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: May 6th, 2012, 11:06 AM
  2. 2010 Camaro 6L80 desired shift times
    By 2010 Bumblebee in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: May 5th, 2010, 05:26 AM
  3. Can I copy one shift pattern table from one folder to another ?
    Last Post: May 4th, 2010, 09:32 PM
  4. Engine Brake Pattern for C4500?
    By 577cc in forum Allison 5 & 6 Speed
    Last Post: January 2nd, 2010, 07:02 AM
  5. LB7/LLY Duramax crankshaft pattern
    By GMPX in forum General (Diesel)
    Last Post: May 27th, 2009, 01:46 PM
