I finally got my wideband signal rerouted the the pcm to simulate the nbo2 so i did a little tweeking to the sd tune i've been running so i could go back to closed loop. On the test drive everything was going good for a few minutes then the afr started jumping all over the place. it would jump around from 17.5:1 then to 10:1 while i was on the highway. I pulled off the road and loaded up my previous sd tune to get me home. I'm home now looking over this tune and i can't seem to figure out why things aren't working right. Any help would be soo much appreciated!
I've attached the SD tune that works great and the CL tune thats not working out
