is it possible to flash an 03 or 04 OS onto an 02 lb7 ecm?
Yes, but why? The 6006 02 is about as good as it gets and has pretty much the same detail in all the data fields as the 044 03-04 OS.
i see i just compared files and no egr and rev limiter in the 01 file. otherwise their the same.
01 has a rev limiter in it as well, but is worked into different tables from the factory. Anything an 01 can do, an 02+ can do plus more. I switched back to an 01 in my BURB simply because I wanted the 850 fast idle, but the driveability of the 01 is nowhere near as nice as the 02 was.
It is an early 02 OS that some have said even made it into 01's as well. It is pretty crude by design and has all the same basic detail as an 01. Even though they have a spot in the OS for an EGR, it doesn't meen that it is used or even activated. MOST LB7's don't have an EGR valve on them, so it isn't activated in it. I'm getting ready to go back to a 6006 OS as the 01 OS has a funky feel to the pedal off idle.
i know exactly what you mean, i did some tuning on an 01 rescently and noticed the weird feel in the throttle. also the 01 had rough shifts when it was stock before i touched it and i noticed in table b0741 in the 7100 os isnt defueling like the tables in the newer os's are.
I have an 01 with the 3376 OS, should I update it? What would I gain?
2001 Chevrolet K2500HD Duramax
Suncoast SCIV 1056
Kennedy twin lift pumps
Billet pick up
MBRP 4" exhaust
Air intake horn mod
ARP head studs
A few more go fast/truck pulling goodies!
Tuned with EFI
12.65 @ 107 1.71 60'
The main improvements will be driveability, more detailed tuning tables, some added tables, and less wierd unexplaineable quirks. I went back to the 01 8873 for about 2 weeks before I got tired of random plumes of black smoke when moderately accelerating, and just all around poor driveability before I went back to the 6006 02 OS. The difference is night and day between the 2 for driveability. The only real drawback is you will lose the 850 fast idle option that only the 01 OS has in it. The 02+ will have a 680 idle VS the 600 of the 01, but I can send you the script to bring the idle back down to 600 like the 01's have.
Where can I find these OS files???
I know what you mean about off idle and smoke plumes now and then and i also get a loppy idle off throttle now and then but it clears up in about 5 seconds.
Thanks.
Jeff
2001 GMC 2500HD Duramax Allison, 4x4 ex-cab, 8' bed, 285/75R16, Sulastic rear spring shackles, Cognito upper control arm kit, Cognito Heavy Duty Tie-Rods, Cognito pitman and idler arm support kit, Heavy duty sway bar end link kit, Banks air cleaner kit with super scoop, AirDog 150 Fuel Preporator/Filter, EFI Live Tuning for power and fuel milage...
