Results 1 to 8 of 8
Thread: Restoring Previous OS ?
    Oct 2005
    Default Restoring Previous OS ?
    When I did the custom OS install, I tried restoring the saved factory OS(full reflash). Then I connected the handheld tuner that came with the Radix kit. Seems that it no longer recognizes the PCM(I get an error message stating that I need to contact Mag to update the tuner).
    I assume then that that PCM has not been restored exactly to it's original state. There must be some check that does not agree with what the dedicated handheld has stored. Is this correct?
    2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
    Gettin' the Groceries
    EFILive will restore it exactly.
    Have you manually changed the VIN (or the BCC) in the PCM? EFILive will not restore that information during a full reflash.
    Is it possible you altered any settings in the PCM using EFILive prior to saving the version you "restored"? If that is the case then those initial alterations may be responsible for the hand-held unit not recognising the PCM.
    Did any reflash failures occur during the full reflash of either the custom OS or the restored OS? If so, PCM identifying data may have be lost, EFILive takes a "best guess" at replacing that data.
    Oct 2005
    RegardsPaul
    I don't recall any failures during the full reflashes.
    The VIN and BCC have never been altered.
    Since the "restore previous OS" attempt I have applied the recent updates to V7.3. Now EFILive also gives me an "Unrecognized PCM" message when I attempt to open the original tun file. The correct VIN and BCC are shown but no cal data is loaded. So now it is not even possible to do a full reflash of the original OS.
    Quote Originally Posted by DrX
    Delete ALL the *.cal files from the folder:
    \Program files\EFILive\V7\Calibrations
    Then re-reun EFILive V7.3.0 installation and select the [Repair] option. That will reinstall the latest calbration files from the V7.3.0 installation.
    Oct 2005
    [Delete ALL the *.cal files from the folder:
    I downloaded the 7.3 installer(I had done the manual install previously). There was no repair option. After the install/repair I now have the missing B3647 issue again. But I can open my original tune. I think that these are the same .cal files that I had when I tried the previous full reflash(i.e. B3647 was still missing at that time).
    Make sure you have the latest calibration files, check the *.cal file's date and version when you first open a *.tun file. The version must be V7.74 or later and the date Nov 13 2005 or later.
    See image.
    Now that V7.3.0 is installed, perform the delete/repair option I explained above.
    Because we provided the *.cal files as seperate downloads and not part of the V7.2 install, V7.3 will not overwrite them. That is because the installer does not recognise the *.cal files as part of any previous install and it chooses not to overwrite them. So you need to delete them manually and then install or re-install and select [Repair] to force the correct *.cal files to be installed.
    Oct 2005
    Oops! I guess B3647 shouldn't have been there because I had the GM OS original *.tun file opened at the time. Must be paranoid about that. I can open all of my *.tun files now with no error messages.
    I will try the restore again tomorrow.
  1. reflash to previous OS
    By goldbergv95 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: December 20th, 2009, 05:06 AM
  2. scanned my trans am. here is what my previous tuner done
    By Aint Skeered in forum Gen III V8 Specific
    Last Post: July 11th, 2007, 06:35 AM
  3. Previous tune using IFR for smaller injectors than fitted
    By stigmundfreud in forum Gen III V8 Specific
    Last Post: July 7th, 2007, 09:33 PM
  4. Previous tune with LS1Edit
    By ibjamin in forum General (Petrol, Gas, Ethanol)
    Last Post: January 15th, 2005, 11:39 AM
