I have a 2008 C6 Corvette Automatic with an LS3 engine and I have ordered the EFI Live Flash scan tool and I'm going to load a new tune from a reputable tuner into my car. But I have a question before I do. The tuner tells me that I can save the original tune and reload it into the ECM and GM will never know it was changed. But some folks on the Corvette forum are saying there is some sort of "flash counter" in the ECM that can't be erased that GM can look at and see the number of times the ECM has been flashed, and that they may void my powertrain warranty if they see the ECM has been reflashed.
I just would like to know what I am getting into before I commit to the tune, and I hoping someone here can give me the straight story. I believe the ECM is an e38, though I'm not sure I know where to look to verify this. "Under the hood" doesn't tell me much, as I can't physically see the ECM since it's behind and under the battery.
Is there indeed a non-resettable flash counter of some sort, and if so, can I circumvent the problem by buying another ECM and flashing it and leaving the stock one alone and putting on the shelf, or is there a counter of some sort in the transmission module too that will tattle tale on me?
Any and all advice would be appreciated. If I can retain my powertrain warranty, I really would like to do so.
