Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Want to start using BBL - $0281
    Feb 2007
    Default Want to start using BBL - $0281
    I've always logged direct to laptop, I want to start using BBL, I've down loaded and updted to the latest firmware and software.
    Formatted config and uploaded pids from scan&tune to V2.
    When connected to the vehicle I select pids (manually as the short cut F1 does not work) and press ok, v2 responds and flahes on the screen with my pid selection (24pids), with ignition on and engine running, I get the error message $0281 no data recieved.
    Any ideas?
    May 2009
    Same here. Fresh install of efi. Updated flashscan firmware to latest. This is on an E67.
    Oct 2004
    Please update to the latest software versions (from here http://www.efilive.com/index.php?opt...=48&Itemid=133) if you haven't already.
    Andrew
    EFILive Crew
    May 2009
    Yep upgraded.
    It used to work long ago on previous version of firmware and/or software. It's been a while since I've touched EFI so this was a surprise.
    I've done many formats of SD and internal memory so I'm running out of ideas.
    The unit works fine on an LS1 (or at least it used to, haven't tried it since the firmware/bootblock upgrade). On the E67 on my 2006 CTS-V it seems to be having issues.
    Any more guidance?
    Which V8 software build do you have installed...?
    Which V2 firmware does your V2 have...?
    Did you:
    - format the Config space...?
    - setup your Options.txt pidlist and program it into V2...?
    - program the latest E67 .pmm file into V2...?
    Did you use S&T software to do those tasks...?
    May 2009
    Did you:
    Formatted config space, copied over options and pmm files from the appdata folder, dtc files.
    Used the new control panel to configure and upload pids in options.
    Flashed it with the latest firmware/bootloader from the website. I believe 2.0.63.
    Thanks for the prompt replies.
    Feb 2007
    I have just down loaded the latest updates
    version 20.6.03 boot block
    version 20.06.35 firm ware
    Formatted memory internal and SD card.
    Opened Efilive explorer, deleted the config files. Refresh and confirmed deletion.
    Opened scan and tune, programmed the V2. Refresh with explorer and confirmed the options.txt and .pmm programmed.
    Connect to vehicle, start engine, select
    F1 Scan Tool
    F1 Select Pids
    Select E40 by pressing OK
    Returns Pids Selected
    F2 Display Data
    Returns the error message $0281 no data recieved
    No joy
    Oct 2004
    When you format the SD Card did you do that while it was in the V2, or from a PC/laptop? If it was from a PC then the necessary folder structure would not have been created and I might expect those error messages in that case.
    I recommend the following:
    - Insert the SD Card into the V2.
    - Open EFILive Explorer.
    - Change to the 'Config Files' tab.
    - Click on the 'Format Config' button.
    - Close EFILive Explorer.
    - Check the 'File sys:' setting on the V2 by pressing the F4-F1-F1 keys. The change the option use the right/left arrow keys and then press the 'OK' button to confirm selection. Perform the following steps with the setting change to both 'Internal' and 'SD Card'.
    - Change to the 'Data Files' tab.
    - Click on the 'Format Data' button.
    What that will hopefully achieve is a clean format of the Config Filesystem, Internal Data Filesystem, and the SD Card Data Filesystem.
    Please let us know how that goes.
    Andrew
    EFILive Crew
    May 2009
    Quote Originally Posted by Tordne View Post
    Tried the above but no joy. Reset PIDs using the control panel, did a program all as well.
    Feb 2007
    The SD card was formatted in the V2.
    Following your instructions above, formated the config file, confirm that the V2 is set to auto for the internal and SD card. Re open efi explorer, select the data tab, press the format button and i recieve the attached (screen shot) error message. Cannot format from efi explorer...
    Anyway, reformatted the sd and internal memory using the V2, programmed the options and pmm filesusing the scan & tune software, connect to vehicle and recieve the same error code.
  1. Error $0281....no data received
    By y2k2z28 in forum FlashScan V2 BB Logging
    Last Post: October 23rd, 2016, 11:08 AM
  2. BBL Error 0281
    By LS2_307 in forum Black Box Logging
    Last Post: January 28th, 2010, 01:10 AM
  3. $0281 error when clearing DTCs - fixed
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: May 27th, 2008, 11:14 AM
  4. Error $0281 on DTC Clear?
    By Donovan in forum FlashScan V2 BB Logging
    Last Post: May 21st, 2008, 02:59 AM
