I just downloaded my existing tune and was stumped when I came across the Cylinder Volume value under
Engine Calibration
Fuel
Air Flow
Parameters
It shows the cylinder volume at 708cc's I should be 785cc's.
My question is, where does the 708 cc value come from. Is this actually stored in the PCM or is it calculated by Flash Scan?
The next question is, assuming this is an actual parameter in the PCM, do other tuning softwares allow the user to change this parameter?
