Results 1 to 5 of 5
Thread: 4x4 shifting
    Nov 2006
    Default 4x4 shifting
    Is there a way to make the throttle a little less responsive in 4 low? I thought there use to be a table with 4x4 shifting and such in it but I am not finding it.
    2004 GMC ECSB Z-71 AEM Longtubes Modified with 3" Magnaflow, Intake, EFI Live, PLX Wideband, 206/212-.515/.522 112, stock heads milled .030", Patriot gold dual springs, comp pushrods, E-Fans
    There should be different shift settings for 4WD, but it only deals with the transmission part of the PCM. I havent seen where you can make the throttle open slower (aka add TM back in).
    Lifetime Member N0DIH's Avatar
    Jan 2006
    That is what I was thinking, impose a less torque limit, then TM will get more aggressive.
    I owned a Ford once, ONCE.......
    Nov 2006
    But is there a way to limit it in just 4 low? Everything is fine on 2wd on the street just 4 low can be a little jumpy from time to time. I saw a review on a new for the other day and the throttle maps are different from 2wd to 4wd to 3lo was thinkin that sure would be nice to have if at all possible.
    2004 GMC ECSB Z-71 6.0L 219/230 .606/.605 114+4, Patriot Gold Springd, AEM long tubes, 3" magnaflow, PLX Wideband, Comp pushrods, E-Fans
    old setup 5.3 AEM Longtubes Modified with 3" Magnaflow, Intake, EFI Live, PLX Wideband, 206/212-.515/.522 112, stock heads milled .030", Patriot gold dual springs, comp pushrods, E-Fans
    Nov 2006
    so anyone come up with anything for this. I looked into the throttle tables and tm tables and dont really see anything that I can make work for throttle control and it not effect everyday driving. Would are pcm be able to handle a low range throttle table or not?
  1. Trans not shifting at WOT
    By acsf in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 9th, 2009, 12:34 AM
  2. What is the difference between shifting VSS and RPM?
    By odd boy in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 19th, 2008, 05:34 PM
  3. LS1 PCM Performance shifting
    By Cougar281 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 01:31 PM
  4. 2-3 not shifting
    By ASSAMI in forum General (Petrol, Gas, Ethanol)
    Last Post: March 6th, 2007, 10:43 AM
  5. Sloppy Shifting H2
    By dfe1 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 16th, 2005, 03:17 AM
