Results 1 to 10 of 11
Thread: Serious problems with full flash for DSP5
    Apr 2007
    Default Serious problems with full flash for DSP5
    I have a 2006 Duramax LBZ that I am having major issues with. I have attempted a full flash to install a DSP5 tune. The V2 sends an error message at 7:07 on the countdown timer. This is also at 191k of flash. I now cannot start the truck. I cannot reflash the truck. I cannot download a tune from the truck. I have rebooted by disconnecting the batteries for 15min the reconnecting and reattempting with no success.
    I was able to pull a DTC from the scan tool. It is:
    B2911 “Wrong Environment Identifier Received From Device 7”
    Any help is appreciated!
    Jan 2008
    never heard of that.
    Jul 2004
    Can you read out the current tune?
    Can you put the stock tune back in.
    Do you have any after market things on the truck? Radio, GPS, performance monitor, if so pull the fuses. Doors closed, handbrake on to keep the lights off, fully charged battery.
    Ira
    Apr 2007
    I cannot read the current tune
    I cannot install the stock tune
    I have a remote start that I will remove and attempt again today.
    Batteries are fully charged.
    Doors are closed.
    Lights are off.
    We'll see if the removal of the remote start makes a difference.
    Apr 2010
    are you sure it was a LBZ tune and not a LMM? that can kill a ECU for sure. are you located near Paducah?
    Thanks Madmartin
    Apr 2007
    Positive it was LBZ
    I am between Lexington and Louisville.
    Apr 2010
    Gman you can call me at 618-949-3898
    Thanks Marti n
    Mar 2007
    Did you turn off the computer and reboot the computer, then reopen the tune you are trying to load. Also turn off the "use high speed" and click try alt keys.
    2007.5 RCLB 4x4 WT LMM 8594OS
    Can you full flash the stock tune back in?
    Jan 2008
    any word?
  1. Pre Full Flash to Full Flash Tune Question
    By Donovan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 13th, 2010, 12:43 PM
  2. Full Flash
    By L31Sleeper in forum Vortec V6/V8 Specific
    Last Post: November 26th, 2009, 10:25 PM
  3. trying to full flash tcm
    By j-man345 in forum Allison 5 & 6 Speed
    Last Post: August 12th, 2009, 03:03 PM
  4. HELP cant full flash
    By Madspeed in forum Duramax LLY
    Last Post: April 23rd, 2007, 07:05 PM
  5. Full flash
    Last Post: June 11th, 2006, 06:28 PM
