I don't see it on the 094 LMM, the patch for locking down the tune. I did plug in before loading the tune.
Is it there, and I'm not seeing it?
Custom Tuning Services
It's there on 094 from what I can see, on the DSP equiv of 094 it's automatically applied when you upgrade to DSP5.
where is it enabled? Looking for a red folder, correct?
When upgrading to DSP on the Bosch ECM the patch is applied automatically without the option to not do it intentionally, because of the tricks that Ross had to do to get the DSP folders to reside in an extended section of the ECM memory that is not readable. Therefore, there is no way to read the tune back out of the ECM in it's entirety, so Ross just locked it for your protection, so that the end user would read out a partial tune that would be unusable.
As for the 8594 OS... I see the patch folder there when i plug in my Autocal.
ok, thanks.
