OK I'm hoping someone has seen this before or maybe I'm missing something totally stupid. Using serial port into my v2. LC1 reads 14.7 at idle give or take of course but it looks fine on my gauge and on my logworks software. I connect it to my v2 and it seems it is reading correct in lamda and eq. Operative word... SEEMS LOL. I will admit that I'm lamda and eq retarded but either way both are close to 1.000 @ idle and fluctuate like I think they should. I watched both and when I'd rev it I would see like a .8xx lamda and 1.1xx eq or somewhere in that area and vice versa on decel.
But for some reason on my v2(8.1.2 build 95) and on scan 7.5.6 build 115 the AFR is showing somewhere in the area of 4.0-6.0:1 AFR, and it would make sense that they match but it makes NO SENSE that it is that far off from what my gauge/logworks is reading.
If anyone has had this issue I could sure use a little help. I've been searching for a while and I couldn't find any threads with an issue like I'm having.
I don't have any logs and I'm not sure that would be even important at this point. I need to make sure everything works before I even start on that.
Kris
