Results 21 to 30 of 36
Thread: Autocal?
  1. #21
    Nov 2007
    I don't have a problem buying 5 at a time I was just expecting the price to be a little lower.
    What is the MSRP on these ?? The The DiabloSport Predator retails for $375
    That only leaves $75 for tuners to make with the autocal ?
  2. #22
    Aug 2005
    The DS Predator cannot and will not ever be able to tune the T43, only the Trinity and their Predator replacement, the inTune will be able to and the pricing will certainly be higher on it.
  3. #23
    Quote Originally Posted by L31Sleeper View Post
    So the autocal can hold 8 licenses but only 3 tunes ?? How are the licenses applied to the autocal ?
    Can the autocal do a COS or DSP ??
    AutoCal has 6MB of storage which can hold between 2 and 8 tunes depending on the size of the *.ctd file. (We are working on making the *.ctd files smaller).
    You can copy tunes to/from AutoCal to your PC/laptop so really there is no limit to the number of tunes you can use with AutoCal. The only limit is the number that you can have on there at any one time.
    Originally AutoCal was only going to have one VIN license but after extensive consultations with our resellers it was clear that allowing multiple vehicles per AutoCal device to be flashed was prudent. It covers that most obvious case where a tuner sells an AutoCal to a customer and that customer has multiple vehicles that he want the tuner to manage. In that situation the customer only needs one AutoCal.
  4. #24
    We (EFILive) don't consider the AutoCal to be a product that will normally be on-sold by tuners to their customer "as is" for any sizable retail margin.
    The value-add (i.e. the tuner's margin) is realized when the tuner adds a tune to the AutoCal device. That's what AutoCal has been designed for, a tune delivery platform.
  5. #25
    Nov 2007
    They don't have to be. The AutoCal's can be licensed to any FlashScan device.
    If a tuner is selling an AutoCal to a customer who does not have a FlashScan, then the tuner would license the AutoCal to his own FlashScan and manage the customer's tunes himself.
    If a tuner is selling an AutoCal to a customer who does have a FlashScan, then the tuner could choose to allow the customer to license the AutoCal to the customer's own FlashScan. In that case the customer would be sort of "on his own" since only the customer himself could create tunes for the AutoCal now that it is licensed to his own FlashScan.
    So why would the web site be looking for a FlashScan SN on check out ??
  6. #26
    Nov 2007
    I guess if you count the license that it comes with, that offsets the cost by 100 bux.
    How are licenses added to the autocal ??
  7. #27
    Just like a V2, buy a license from EFILive, they email you the confirmation code, you put it in just like adding a license to a V2, and done.
  8. #28
    Nov 2007
    Does the AutoCal come with it's own serial # ??
  9. #29
    Oct 2004
    Yeh it sure does (has to actually for licensing). When you "link" an AutoCal to a FlashScan V2 the serial number of the V2 is burnt into the AutoCal license field.
    Andrew
    EFILive Crew
  10. #30
    Nov 2007
    So if the SN is the same how do you know which device the license is actually going on to ??
  1. Autocal
    By Frost in forum Lounge
    Last Post: May 10th, 2010, 01:27 PM
  2. AutoCal?
    By Highlander in forum FlashScan V2
    Last Post: December 18th, 2008, 07:41 AM
  3. Autocal
    By Alvin in forum Lounge
    Last Post: August 1st, 2007, 01:55 PM
