Hi Folks:
Just installed my DSP5 switch and it works fine except on one setting. On my setting #1, I only can get 58mv for a reading??
I have my switch set up as follows:
Switch setting #1 is my stock tune and the voltage is 58mv. (???)
Switch setting #2 is an econ tune and the voltage is 3.53 volts.
Switch setting #3 is a 60hp tune and the voltage is 2.36 volts.
Switch setting #4 is a 70hp tune with turbo brake and the voltage is 1.45 volts.
Switch setting #5 is an "anti-theft" tune and the voltage is 0.49 volts.
All the settings work as they should except for #1??
The truck runs in settings 2, 3 and 4. It shuts off and or won't start in setting 5 as it should. But it also shuts off and or won't start in setting 1 because of the low voltage. I believe I should be seeing about 4 to 4.5 volts?
These are readings off my DVM and the my computer with EFI.
I've checked my resistors, switch and wiring and all is good.
Could there be a problem with my DSP5 tune?
I am puzzled and getting frustrated with this DSP stuff.
If someone could please help me out that would be very much appreciated.
I'll give it another try as I think I am close.
Please accept my thanks in advance for your help.
Garry
