I can't open a BBR with tune tool. Copied from EE to tune tool, renamed to .tun-wont open.
7.5.6 Build 116 - 8.1.2 Build 97
You can't rename the file from '.ctd' to '.tun'.
Right click on the '.ctd' file, then choose "Open With", "Choose Program" and then "Browse". Browse "C:\Programs\EFILive\V7.5\" and select "EFILive_Tune.exe". This should associate '.ctd' files with the Tune Tool and then you can just click on the file and Tune should open with that file.
I think I got all the step correct, but that should get you to the right area.
Yes, Ninety8C5 has it correct... do not rename the file, just open the .ctd with the tunetool.
That works! Truth be told though I thought that is how I tried originally, maybe not.
Thanks once again
