Results 1 to 6 of 6
Thread: Cant open ctd file
    Oct 2006
    Default Cant open ctd file
    I can't open a BBR with tune tool. Copied from EE to tune tool, renamed to .tun-wont open.
    Which V7 and V8 build versions...?
    Oct 2006
    7.5.6 Build 116 - 8.1.2 Build 97
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    Quote Originally Posted by VHR View Post
    You can't rename the file from '.ctd' to '.tun'.
    Right click on the '.ctd' file, then choose "Open With", "Choose Program" and then "Browse". Browse "C:\Programs\EFILive\V7.5\" and select "EFILive_Tune.exe". This should associate '.ctd' files with the Tune Tool and then you can just click on the file and Tune should open with that file.
    I think I got all the step correct, but that should get you to the right area.
    Yes, Ninety8C5 has it correct... do not rename the file, just open the .ctd with the tunetool.
    Oct 2006
    That works! Truth be told though I thought that is how I tried originally, maybe not.
    Thanks once again
  1. cannot open file
    By 1hotduramax in forum General (Diesel)
    Last Post: September 17th, 2008, 12:46 PM
  2. Open loop or semi open loop still?
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: October 18th, 2007, 02:46 AM
  3. Semi-Open Loop Vs Just Open Loop
    By BowlingSS in forum Custom Operating Systems
    Last Post: April 14th, 2006, 04:25 AM
  4. If I open an HP file from Horists site W/EFILIVE, can I load it right into my pcm??
    Last Post: December 28th, 2005, 08:43 AM
