I just looked at your log and there is a P0717 Input speed sensor low voltage, so there's your problem! There must be a wiring issue....
Lee
Lee
230" Dragster - 2000 LS1, 02020003 Speed Density, PRC 2.5 Heads,
MS3 Cam 237/242 .603/.609, Vic Jr. intake, Holley 1000CFM TB,
PowerGlide, 5000 stall converter. 8.70@154 MPH
My Projects Homepage: http://www.horsepowerracing.com
Max line pressure in this condition is turned off in the tune file. That adds to the confusion.
The Tremor at AIR
Driving a truck with a BLOWN engine has two meanings. I get to experience BOTH on a regular basis
2006 GTO....in progress
2002 6L/80E/Radix/ Tahoe
should be the rear sensor but I would check both and make sure theyre not crossed.
P0717
Input/Turbine Speed Sensor Circuit No Signal
Not sure what that means lol
Hmm, well 2 days ago I found that the sensor was wired backwards and thought I had solved my problem so I reversed the wires and it made no change. Any chance the sensor is bad? Maybe burned up from being plugged in wrong? Seems unlikely since this sensor is the same as the first day I started the engine and trans. Unless it was bad from day one.
I've experienced the sensors going bad on several occasions. And in your case since this has been an issue for so long I wouldn't hesitate to replace it. They're cheap anyway.
Part number?
