Results 1 to 10 of 11
Thread: Can't get '06 GTO to start on key only.
    May 2009
    Default Can't get '06 GTO to start on key only.
    This is a heads/cam (238/242 duration) car. I upped idle speed to 825rpm at warm idle areas.... too much less, and the car would set misfire codes and map out of range errors
    I cranked the crank airflow to max values to try and get it to start, I upped the Park position minimum idle airflow column to match actual running airflow (15 g/s).
    I zerod out the flare control spark table.
    I upped cranking timing.
    None of this made a difference imho. I still have to go at least 1/4 throttle to get it to start.
    Also, there is a long delay before it will idle upto commanded idle speed...
    Any suggestions?
    Senior Member MyM8V8's Avatar
    Aug 2008
    Have you drilled the butterfly? (throttle body blade)
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
    May 2009
    Quote Originally Posted by MyM8V8 View Post
    Hahahaha... no. Shit, we used to do that back in the 80's. You mean we still have to?
    Aug 2008
    Don't laugh!!! It worked for me! I just drilled a 4mm hole and all the problems I was having went away.
    May 2009
    Thought about that when i could not get the betterfly to open over 20%...
    Jul 2003
    Do not drill the TB hole.. your's is drive by wire and you can tune it out...
    Aug 2008
    Quote Originally Posted by Highlander View Post
    So is mine. I spent forever trying to tune it out until some one told me to drill it, and hey presto, it worked. (I did port the TB at the same time but i doubt the porting had anything to do with it)
    Any chance of a to do list for an E40 dbw?
    Oh, btw, mine idles nice now at 650 .
    Lifetime Member jfpilla's Avatar
    If when porting the TB the ridge was touched it will create some startup and/or idle issues.
    If you have not done so, try reducing your VE's.
    1200 rpms (-10%), 800 (-20%), 400 (-30%).
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Aug 2008
    Quote Originally Posted by jfpilla View Post
    Cheers. I did pretty much try everything before drilling.
    I was very careful not to disturb the ridge as I thought it could create issues. But I had the idle problems way before I decided to drill. I ported and polished the TB when it was off for drilling, not before.
    I should have been more clear. I was responding to the original poster. He should try this before putting a hole in his TB.
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
  1. COS and no start
    By turbogtu in forum General
    Last Post: September 15th, 2009, 02:27 PM
  2. Cold start perfect, Warm start flares high
    By samh_08 in forum Gen III V8 Specific
    Last Post: May 12th, 2009, 09:36 PM
  3. Cold start great but warm start sucks."Idle
    By mvvette97 in forum Gen III V8 Specific
    Last Post: October 26th, 2008, 12:22 AM
  4. Where to Start on an LB7?
    By LBZoom in forum Duramax LB7
    Last Post: October 7th, 2008, 07:30 AM
  5. Help, no start!
    By Leadfoot in forum General (Diesel)
    Last Post: October 2nd, 2008, 09:51 AM
