Results 1 to 10 of 14
Thread: Bucking Returns
    Feb 2006
    Default Bucking Returns
    Hi,
    I have recently leaned out my off load areas and the dreaded Bucking has returned
    I could of course just revert to my old tune.....but where would be the fun in that
    Would a kind soul let me know what PIDs I should be monitoring to check what's happening with the Spark Timing at low rev/low load (only happens at 1500-2000 RPM).
    COS3, WBo2, no O2's, No EGR/Air, No Aircon, No Cats etc etc 224/230 TR230 LSA111 Cam.
    Jim
    2000 LS1 M6, No EGR/Air/PS/CATs. TR230 Cam, COS3, OLSD, LC1 Wideband fitted, Procharger P1SC, 2 Bar MAP, Siemans Dekka 60Lb Injectors.
    All wrapped up in a 2000Lb AC Cobra Replica
    Apr 2007
    Why is the Commanded AFR so lean? That's part of the problem. Looks like the bucking is on decel. I have to believe the combination of the Commanded AFR and DFCO is causing the problem seeing the WB reading is between 18-20 AFR.
    Jan 2005
    Looks like you did more than lean out the mixture. You also altered a number of timing tables. Since you're timing is jumping around like a politician being pressed to answer a question honestly, look at the timing changes you made. Your idle overspeed/underspeed timing corrections look too aggressive for the camshaft you're running. Log DynCylAir_DMA so you can see the timing table cells that are relevant to your log. I primarily looked at your log for idle conditions and it looks like one of the issues may be a big discrepancy between values in your primary spark tables and in the idle spark tables. That combined with the overspeed/underspeed settings is a big part of the idle/low speed spark inconsistency. Although there are slight variances in air flow, they aren't large enough to cause the spark bouncing around to the degree it is.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Jul 2008
    What everybody else said. I buck if I go that lean. I can handle the DFCO lean..but I would richen it up in those other areas..along with all the extra great advice on spark.
    Curious, you say no MAF or you are running MAF? Don't see a DTC Code on it? I know you are Open-Loop..but something to think about..
    If you don't get a MAF DTC then it will still run from the MAF...
    Good luck.
    Feb 2006
    Thanks for the advice, I'll Richen it up a bit.
    Maf is fitted and working (guess I need to update my footer )
    Dfe1 - thanks for tips, I'll work through them tomorrow and see how it goes.
    Many thanks
    Jim
    Feb 2006
    Had a brief run out with some of the suggestions enabled and logged the results....and then realised that I hadn't programmed the correct PIDs - hey ho! - then got distracted by the hot weather (very uncharacteristic in England :-)).
    Anyway, just had a good look through S&T and selected a bunch of PIDs and did a quick 30 sec log to make sure I've got the right ones...
    Question - have I got DynCylAir_DMA in there? (if so, I'll go drive and log) I couldn't see it in S&T so selected what I thought it might be?? (or do I have to manually do it via Options.txt?)
    Jim
    Jul 2008
    Quote Originally Posted by Happy Jim View Post
    Jim
    Jim:
    Your OS should have DYNCYAIR_DMA available. Look under 'Tune" in your Pid Selection File (see attachment).
    Did you get rid of the bucking?
    Feb 2006
    Shawn, thanks...found the little bugger now :-)
    It's been a long long time since I used the Scan tool to play with PIDs, I'm struggling to program them into the V2 (only vaguely remember doing this with the V1) - The "Programme selected PIDs into Flashscan" is greyed out which I'm sure is telling me I've got something wrong (sequence of connecting the V2 to car/pc maybe??).
    The bucking never went away with the tweaking I did above, although it did improve. I've gone back to my "best" tune and can actually feel the bucking in the same area - guess I'd just got used to it and drove around the problem (it's not bad, just noticable). Once I've got the right PIDs loaded I'm going to use my "best" tune as the baseline and then apply the adjustments mentioned above (changing the base spark table seemed to make the biggest difference (SOTP).
    Jim
    Jim, to program pids into V2 you have to use the S&T software.
    Feb 2006
    Started with "GD J1m 10 May Start.Tun", changed the Idle over/underspeed settings (set them to 50% of previous max value and then a linear ramp to zero), changed the base spark table to be the same as the High Spark - went for a quick run, definate improvement SOTP (I'd say 85% of it has gone), haven't looked at the log yet but will in a min.
    Thanks for the pointers guys, much appreciated.
    Jim
  1. 1600 RPM Bucking Bronco
    By tazinhawaii in forum Gen III V8 Specific
    Last Post: September 24th, 2008, 09:09 AM
  2. No bucking....but pinging!
    Last Post: February 22nd, 2008, 02:43 AM
  3. Unknown Bucking???
    Last Post: January 14th, 2008, 12:41 AM
  4. What causes "bucking"
    By zapp168 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 4th, 2007, 12:49 AM
