Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: using 2001 Z06 tune on 99 camaro Z28?
  1. #11
    Nov 2006
    What I did for the switch-points was start @ 450 mV then use BEN after filtering out ECT & OL commanded EQ.
    Basically any time commanded EQ = 1.00 BEN factor was applied to {B4105} ( both banks at the same time).
    LC-1 WBO2
  2. #12
    Apr 2010
    yeah i left the switch points as stock about 456 mv for most CL modes, just with headers now I have heard they might change, but couldn't tell unless I get a WB
    Yeah thats the knock in the log joecar, i dont know why it does it or if it is a shock down the drive shaft during gear change? funny it only does it sometimes??
  3. #13
    Lifetime Member smslyguy's Avatar
    Oct 2008
    I was having the same problem with my 01 ss spark knock as well. I see you and i basically have the same mods. I get random spark knock even with the burst knock zerod out. I have yet to figure it out, But nice 1/4 mile run.
    2001 camaro z28 ss vert with factory slp upgrades, Hooker long tubes, 3"y-pipe to a 4" muffler, ,airlid,s.s.r.a. ,t.c.bypass,descreened m.a.f. 232/234 .595,.598 +2 comp cam with ported and polished stock heads with .650 lift dual springs and a bowl grind. tuned with EFI Live. All combined to achieve 29 m.p.g. and 399 r.w.h.p. with 384 lbs of torque. sold...
    Now own a 2015 1LE camaro
  4. #14
    Apr 2010
    thanks on the run,
    yeah, well i clearly still got that bit of knock but no ideas why other than that i need to increase the burst knock threshold more currently at 0.1 grams/cyl. If not the knock could be my exhaust bannging? the diff clunck when the gear engages? or due to my MAF calibrationif it fluctuates more than the 0.1 (which I dont think is should too much?)
    ill have a bit more of a play, i really need a good track or a dyno to check it i have got an advantage from the spark change or not as i couldn't get a consistent 0-60ft time really
  5. #15
    Oct 2008
    Quote Originally Posted by maudyZ28 View Post
    thanks on the run,
    I zero'd b6210 all across the board and it pretty much eliminated all the "burst" knock.
  1. 3.6 camaro tune
    By whackem04 in forum E37, E38 & E67 PFI ECM's
    Last Post: December 18th, 2009, 10:45 AM
  2. Need tune for 2001 Camero LS1
    By flyguy_17 in forum Gen III V8 Specific
    Last Post: March 18th, 2009, 07:28 AM
  3. 2001 Vette Stock Tune Needed
    By finishline in forum Custom Operating Systems
    Last Post: March 30th, 2008, 01:41 PM
  4. 2001 4.3 blazer tune?
    Last Post: May 7th, 2006, 02:45 AM
  5. 2001 WS6 stock tune file?
    By joecar in forum General (Petrol, Gas, Ethanol)
    Last Post: March 1st, 2005, 05:55 PM
