Results 1 to 10 of 10
Thread: Low fuel rail code P0087
    May 2009
    Default Low fuel rail code P0087
    I have two race tunes and one keeps throwing a code. So Im guessing it demanding to much fuel. Do I take fuel out of fuel pressure base or main injection pulse? Thx
    06 LBZ CCSB
    A few bolt on's!
    Lifetime Member LBZoom's Avatar
    Jun 2008
    take it out of pulse, your pulse is opening too long and the pump can maintain pressure anymore. You'll either have to bump fuel pressure or reduce pulse width. Look to maintain a 23,000 psi pressure or higher. hope this helps!
    Peace Through Torque
    www.PunisherPerformance.com
    May 2009
    I'll give it a shot. THX
    06 LBZ CCSB
    A few bolt on's!
    Feb 2007
    How much pulse width are you commanding? You should be able to hold 3000 uS pretty easily.
    May 2009
    Josh, seen one of your tunes on another forum. Is it stock safe for 06 lbz? Thx
    06 LBZ CCSB
    A few bolt on's!
    Feb 2007
    I haven't heard of anyone having any trouble with it (I assume you mean stock engine and not stock transmission).
    May 2009
    Stock internals. But dyno'd 546 to the wheels not to long ago. Just curious about your tune. Timing 40.9 at the end, may never reach that? Found that my shim kit was not working and replaced it with a race valve. Put a 15psi spring in the AD and BAM prob fixed.
    06 LBZ CCSB
    A few bolt on's!
    Dec 2006
    So if my race tune is throwing 87, I should not suspect a bad relief valve? Instead adjust the tune? Why does this vary from truck to truck? And please explain about the shim kit and the mod you did to get rid of 87. It can cause limp right? THANKS!
    8.7 @ 84 (1/8 mile) bolt-ons
    Dec 2006
    anyone? :(
    Dec 2006
    my problem fixed by relief valve, thanks anyway
  1. P0087 Fuel pres to Low Anyone have this issue?
    By Boostin99SS in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 19th, 2017, 05:35 PM
  2. Fuel Rail Pressure's relationship to fuel economy.
    By duramaximizer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 28th, 2010, 01:18 PM
  3. Question on a LBZ fuel rail pressure?
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 30th, 2009, 07:45 AM
  4. fuel rail pressure
    By drdarthinvader in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2009, 07:17 PM
  5. Fuel Rail Pressure
    By Dave Lewis in forum Duramax LB7
    Last Post: July 30th, 2006, 02:54 PM
