Results 1 to 9 of 9
Thread: 2004 4L60E ????'s
    Aug 2008
    Default 2004 4L60E ????'s
    I'm installing/adapting a 2004 5.3ltr w/matching 4L60E trans into a 57' Chevy Nomad and my question is: Do I need to wire in the Transmission Range Switch Connector to the PCM for it to be able to shift/operate fine? Or will it operate fine just using the Grey 20 Pin plug that controls the shift solenoids?
    I know i have to wire Pin 33 on blue connector to brake switch...
    FLASHSCAN V2 & AUTOCAL
    I believe the engine calibration uses the transmission P/N switch to select the RAFIG or RAFPN idle air tables.
    Aug 2008
    So, the transmission would shift fine without the range selector switch....
    Yes, it would shift fine.
    Aug 2008
    Do I need to wire these to the PCM or to actual switches? Or do I even need them?
    The one's with the redline...
    1)*Clutch Start Switch Signal*
    2)*Park Neutral Position Switch*
    3)*Back-Up Lamp Supply Voltage*
Name:	Gear Seletor.jpg
    Dec 2008
    Quote Originally Posted by GAMEOVER View Post
    Park Neutral Position Switch sends a ground the PCM when in Park or Neutral, the rest dont need to go the the PCM (Clutch Start Switch Signal is for 6 speeds). I wired mine in thru the aftermarket shifter I have (and used the short selector shaft on the transmission, mine is a 4L80E).
    Aug 2008
    Quote Originally Posted by slow67 View Post
    OK, I know I'm probably making this more difficult than it is...
    I can wire up the Park Neutral Position Switch from the Range Selector switch located on the Transmission to the PCM and I'm good to go....
    Dec 2008
    Pretty much. It just adjusts the idle air for in gear and P/N (as Joe stated earlier).
    I used 2 relays for mine (activated by the switch on the shifter) so that it wouldn't start in gear (one relay, 12V passing thru) and the other relay passes a ground to the PCM.
    Aug 2008
    Thanks a bunch slow67 & Joe...it worked...
  1. 2004 oil pressure pid?
    By nonnieselman in forum Petrol / Gas
    Last Post: December 11th, 2009, 04:39 PM
  2. 2004 trailblazer
    By driver456 in forum Gen III V8 Specific
    Last Post: October 21st, 2009, 11:34 AM
  3. COS#5 for 2004 silverado
    By minytrker in forum Custom Operating Systems
    Last Post: September 1st, 2007, 10:51 PM
  4. 2004 Z06 Max Speed
    By dbaxter_ss in forum General (Petrol, Gas, Ethanol)
    Last Post: April 20th, 2005, 09:06 AM
  5. P59 PCM Support for 2004 and up LS1 and LS6?
    By SinisterSS in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2004, 07:31 AM
