Results 1 to 3 of 3
Thread: my desktop and efi live
    Lifetime Member ZL1Killa's Avatar
    May 2005
    Default my desktop and efi live
    I have currently removed all of efi live from my desktop due to issues with upgrading and files. Don't get me wrong, I love efi live ,....just my desktop seems to think otherwise. I use my laptop for tuning...I have my desktop for looking at the logs then making changes
    what is happening is efi live is getting confused between my drives. I have tried to remove all efi live folders and files and uninstalled it properly, then re-install it and it installs multiple efi live folders again.
    I need to know all the registry keys, files, folders and everything of where efi live installs that cannot be found by searching for "efi" under windows search and by uninstalling efi live.
    I will try installing it to another drive and see if it does it right
    01 T/A WS6 #4984 STOCK 342HP and 352TQ [/b]MODS:Too many to list, PM...funny rear mount.. father/son build.
    [Quote :ur car is sneezing!!!!]
    I KNOW KUNG FU.
    My STS build: http://www.ls1tech.com/forums/showthread.php?t=631954
    453HP 475TQ @6psi
    .....CAM'd, IC'd, and 7psi'd #'s coming.....
    Oct 2004
    The Registry key for EFILive is 'HKEY_CURRENT_USER\Software\EFILive'. You can delete that key, and by doing so all its sub keys. This will remove a lot (if not all) of your previous preference settings.
    By default EFILive will install to 'C:\Program Files\EFILive', and will also create a folder structure under 'My Documents\EFILive'
    Good luck.
    Andrew
    EFILive Crew
    May 2005
    thanks, yeh i had a problem once I uninstalled it and restarted then tryed to install it efi live wanted to create a folder on F: and on C: and complained about having the config.ini filemissing....so i had two efi live's installed on my desktop...thats why the 7.3update didn't work right
    I KNOW KUNG FU.
    453HP 475TQ @6psi
  1. Using EFILive offline on your desktop
    By Blacky in forum Tips and tricks
    Last Post: August 21st, 2016, 09:14 PM
  2. Tell me why I should go with EFI Live
    By Mike6158 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 8th, 2010, 01:47 PM
  3. Replies: 6
    Last Post: August 11th, 2009, 04:52 AM
  4. Live tuning for RFI-Live??
    By Bob's Garage in forum General (Petrol, Gas, Ethanol)
    Last Post: September 14th, 2005, 06:27 AM
  5. Tuning From DeskTop
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: March 28th, 2005, 04:16 AM
