Results 1 to 3 of 3
Thread: 2004.5 LLY limping trans?
    May 2010
    Default 2004.5 LLY limping trans?
    Truck now took the tune! now that the tune is on i made the correction for tire size and raised the speed limiter. now when the truck gets to 90mph it will limp the trans? the truck is not running out of fuel nor is it that hard on the trans. is there any speed sensors in the tune that need to be equalled out? any help would be great! thanks guys
    Senior Member lakingslayer's Avatar
    Dec 2005
    Are you getting stuck in 3rd gear? Is your trans stock? What kind of pulse widths are you running?
    Dec 2006
    Without thinking - or knowing - too much, you are either running into the top speed limiter for some reason, or simply limping it due to power and the slippage that is detected in the high gear, no? Good luck and keep us posted
    8.7 @ 84 (1/8 mile) bolt-ons
  1. Gen III 5.3 To Gen IV 6.0 (LY6) 2004 Avalanche
    By spacediver in forum Gen III V8 Specific
    Last Post: March 23rd, 2010, 08:41 AM
  2. 2004 oil pressure pid?
    By nonnieselman in forum Petrol / Gas
    Last Post: December 11th, 2009, 03:39 PM
  3. Problems with 2004 GTO
    By S10Wildside in forum General (Petrol, Gas, Ethanol)
    Last Post: October 4th, 2006, 10:31 PM
  4. 2004 Z06 Max Speed
    Last Post: April 20th, 2005, 08:06 AM
  5. P59 PCM Support for 2004 and up LS1 and LS6?
    By SinisterSS in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2004, 06:31 AM
