R.I.P Shawn, 1956-2011
Looks good.
How do you like that electric water pump? How effective is at cooling the engine? Thought it might be nice to have one, but like everyone else..not spending as much money anymore on modifications..Curious as to its effectiveness and do you really gain any additional HP from it?
Thanks..
i don't know how much i gain from it because i put it when i installed my 408
for the cooling i didn't noticed any difference i think it will be good for 10 hp in the top end because the stock WP will make some load on the crank at higher RPM
EFILive Tuner
Thanks..
You have a very nice setup. Hope you get that Fuel Injector issue solved. Bet that 408 can really scream!
Good luck..
Joe (Moderator)
Good job on the sig...
Great to see the fueling is coming along nicely now. Post up some more logs when you get a chance.
Simon
Joe (Moderator)
+1 post more logs and any tune file updates.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
