I thought no licensing was needed for the 1998 PCM.
Tried to load a tune in a 1998 and I got a message that I need a license to load the tune.
I have the most recent versions of the software for my V2.
Stream is free for 97-98 Ls1 PCM's. You still have to go thru the whole licensing process I think...
FLASHSCAN V2 & AUTOCAL
Just to qualify; it is only the 1997/1998 LS1 PCM (as used in the Camaro and Corvette) that is not subject to licensing. Any other 1997/1998 controller type that might be support will require a license allocation.
On rare occasions there has been a case of a FlashScan V2 being built without the S-LS1A Stream included in wich case we can resolve that by sending your Serial Number and Authenticate Code (as per here http://support.efilive.com/kb_articl...2143-YUOG-8049) to me at support@efilive.com, or better still log a case at http://support.efilive.com/
Andrew
EFILive Crew
Sent an email to support with my info.
Got the key for the stream from Andrew. It's fixed now. Thanks.
330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
GM Performance Centre
Busselton WA
AUSTRALIA
Phone: 0447 003050
Yours has the same thing. Shoot me an email (support@efilive.com) and I'll send you the activation code back.
Andrew
EFILive Crew
no worries
sent detail to you
Busselton WA
AUSTRALIA
Phone: 0447 003050
