WB not found.OK what did I miss or what do I have to do to get it to work.Its a PLX...Thanks..................Paul
V2 or V1 , analog or digital ?
2006 Trailblazer
Make sure you have the correct PIDs selected like here :http://forum.efilive.com/showthread....ht=#post102366.
2006 Trailblazer
I don't have calc ben for some reason,Is that the one I need? I don't really get what you showed me.
Paul, are you using analog or serial connection between LC-1 and V2...?
If you have analog, then you have to select the following pids: CALC.BEN_LC11, CALC.AFR_LC11, EXT.AD1, GM.AFR.
Are you using V2 BBL...? If so then run the S&T software, goto F6:Device Settings, F6:BBL (Logging), checkmark Automatically select all analog pids...
Then Save to file, Program to V2.
What Chevy366 is referring to is that with the serial connection you will get accurate AFR data as this avoids analog connection problems (voltage offsets and poor resolution).
Last edited by joecar; May 30th, 2010 at 06:34 AM. Reason: forgot GM.AFR... thx mr.prick.
LC-1 WBO2
In pass thru mode the WB works.I have a A/F gauge in the dashboard of my truck and it shows 14.6 and on my laptop when I'm logging it shows 15.2 Is there an adjustment for that? The other thing is in S&T V8 I don't have CALC.AFR_PLX1,CALC.BEN_PLX1.I only have EXT.AD1 or I'm I missing something.
You add the WB PIDs to the log after you open it.
You may not be able to match the gauge to your stoich AFR.
Is it adjustable?
How to match wideband output to {B3601}
LC-1 WBO2
Like mr.prick said, you add the calc pids when viewing BBL log with scantool.
