Results 1 to 4 of 4
Thread: LBZ ECM dead after reflash & recovered
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Default LBZ ECM dead after reflash & recovered
    Ross and Paul, just an FYI, you might want to remove C2201-C2206 from the LBZ ECM calibrations. If you change them (I only changed C2205 to 4V, but I assume any of them would have the same result), and after the cal flash, the ECM was brain dead. No crank, no guages, Tech2 just looked at me like "Yeah? And?". V2 didn't detect the ECM, just the TCM & GPCM. Fortunately EFILive was able to recover the ECM and it's alive again. Apparently there's SOMETHING that allows the ECM to know something's changed and kills itsself.
    Jan 2008
    was that in your swap?
    Jan 2006
    Quote Originally Posted by bballer182 View Post
    Only in so much as I was trying to get the ECM to be happy with the gasser pedal until the LBZ one arrives. It's ticked even with the pedal DTC's disabled, and changing the voltage in the Pedal diagnostics results in a dead (but recoverable - at least in my case) ECM.
    Jan 2008
    Yeah the way those DTC's report in the Bosch ECM's is weird. Like there might even be more tables that deal with DTC's that Ross doesn't know about.
  1. Dead 02
    By waterbug1999 in forum Gen III V8 Specific
    Last Post: July 13th, 2009, 09:29 AM
  2. [B]HELP[\B] Another Dead PCM
    By ls1vt209 in forum Gen III V8 Specific
    Last Post: March 26th, 2009, 04:13 AM
  3. Dead Battry after reflash?
    By kbracing96 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 30th, 2005, 11:59 AM
