Results 1 to 10 of 11
Thread: 2002 F-Body missfire during AutoVe
    Aug 2008
    Exclamation 2002 F-Body missfire during AutoVe
    Was doing the AutoVE on a 2002 5.7 6 Speed, everything was going perfect and all of a sudden it went Extremely Rich. Pulled over, shut the motor off, did a free-air calibration on wideband(Innovative LM-2) turned the motor back on and motor has a real bad missfire, motor shake's, stumble's between shift's.....Wideband is showing rich AFR(12-13.2)....Before incident AFR was 14.5 in all part throttle areas, under 4000RPM, & Ben's were .99-1.01 .......I'm going to do a compression test today but hopefully it's something minor..... Any ideas on what might have happened?
    Stuck open injector?
    Bad coil?
    Everything was going perfect...
    FLASHSCAN V2 & AUTOCAL
    If coil is bad, then unburnt fuel/oxygen would pass thru, wideband would see excess oxygen (lean).
    If injector leaks then wideband would show rich like you indicated.
    Is it valid to perform free air cal when gases may still be present in exhaust...?
    Don't you have to get out residual gases first...?
    Aug 2008
    I actually unbolted wideband from vehicle and performed free-air cal, (small portable jack...)
    Aug 2008
    Performed compression test and #1 cylinder showed 1psi, cylinder's 2-8 showed 140psi average....
    Removed valve cover & on cylinder #1- Comp Cams roller rockers were just laying on top of head...
    Chromoly pushrods were OK, but aluminum Rocker mount was broken at base of rocker. It split like a popsicle stick.....
    Ouch, rocker mount just broke...
    Insufficient air, injector fires, plug fires resulting in rich combustion...
    Pics...?
    Ah, I knew you would have performed free air cal in free air...
    Aug 2008
    I took a pic with cell-phone kinda bad quality...
    Oct 2006
    Yikes. Hitting those 8000 rpm cells has a tendency to do that. (joke)
    I had an exhaust roller rocker let go on mine as I was on the way to pick my daughter up. I was glad it happened then & not a few hours earlier when it was being pushed to 7000RPM on the dyno. (I wont mention the brand as they went out of their way to rectify the situation)
    The Tremor at AIR
    Why did the rocker mount break...? I have one in my hand here and it does look very light.
  1. body control module on v6 2002 camaro
    By Aint Skeered in forum EFILive V6
    Last Post: July 16th, 2008, 12:12 AM
  2. Does any body have a OS 2000 to 2002
    By RandyWS6 in forum Gen III V8 Specific
    Last Post: August 21st, 2007, 08:40 AM
  3. How to delete Missfire at low RPM'S
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 10th, 2006, 11:22 AM
  4. I have a 2000 F-Body; should I change to a 2001 or 2002 OS?
    By leres in forum General (Petrol, Gas, Ethanol)
    Last Post: August 26th, 2005, 05:44 AM
  5. 2001-2002 F-body LTFT cell RPM boundary values
    By joecar in forum General (Petrol, Gas, Ethanol)
    Last Post: February 8th, 2005, 08:54 AM
