At your altitude, you should be running pretty solidly in the medium altitude boost tables and maybe even partially into the high altitude tables. You need to make sure you are adjusting all the boost tables to match your desired boost. Also, keep in mind that when you run higher RPM, the amount of air consumed by the engine becomes increasingly larger. You may be exceeding the lbs/min of air the stock turbo can flow thus diminishing the amount of boost pressure. You may be able to get more boost out of it, but you run the risk of pushing the turbo outside its map. I'm not saying that is what is happening, but it is a possibility and something you should keep in mind. It is even more likely at your high altitude.
