Results 1 to 4 of 4
Thread: Can't get stock tune downloaded on laptop
    May 2010
    Default Can't get stock tune downloaded on laptop
    So i've tried a variety of ways. I've done it w/out pulling fuses w/ and w/out the keys button clicked and ive done it with every variation of pulling the radio and info fuse. If i pull the info fuse and leave the radio fuse in it will start the download and get stuck somewhere between 5k and 51k. At any time if the radio fuse is pulled the laptop wont even make it through the status check. I've also checked to make sure i didn't have any blown fuses so I not in a very pleasant mood right now because I can't get this damn thing to work. Any help would be greatly appreciated.
    My truck is a late model '04 with an aftermarket stereo, but i have the wiring chime harness thing.
    Thanks,
    Brett
    Senior Member JustinD's Avatar
    Jul 2009
    LLY's are the worst, keep trying, make sure the doors are closed all the lights are off, anything that communicates will disrupt it. Try restarting the laptop, open EFI, then plug it in, the open the file. I have had these issues before also. Check to make sure no one has used the OBDII port to jump power for anything, I have been trying a truck that has a Compu car alarm, they used the OBD port for power it wasn't cooperating with me either.
    Good luck.
    2001 Chevrolet K2500HD Duramax
    Suncoast SCIV 1056
    Kennedy twin lift pumps
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    A few more go fast/truck pulling goodies!
    Tuned with EFI
    12.65 @ 107 1.71 60'
    May 2010
    Well the truck was a work truck so its barebones. Only thing is I have an aftermarket stereo, but i even tried taking out the head unit and its still not working. The computer has been on/off multiple times. One of the cig lighters doesn't work but the fuse is just fine. So I can't really think of anything else at this point. Starting to get extremely frustrating.
    Pull all radio related fuses, aftermarket radios and adapters are HORRIBLE at following the proper bus comm protocol for shutting communication off (read, they dont at all and stay active when they shouldnt).
  1. Replies: 5
    Last Post: March 26th, 2009, 02:06 AM
  2. Tune VE and MAF tables or leave VE stock and tune MAF only
    By BlackGMC in forum Gen III V8 Specific
    Last Post: August 4th, 2008, 08:05 PM
  3. Just downloaded 7.5.3 but............
    By Sparky8370 in forum FlashScan V2
    Last Post: June 18th, 2008, 11:19 AM
  4. New laptop and V7.3.1, Is my old v7.3 pre release tune compatible??
    Last Post: April 2nd, 2006, 03:51 AM
  5. downloaded 7.1.7 but charts still missing?
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: January 31st, 2005, 09:21 PM
