Results 1 to 2 of 2
Thread: Fuel and RPM limit question...
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Default Fuel and RPM limit question...
    Hey guys,
    Quick question, in the pedal position to desired torque table the RPM columns jump from like 3550 up to 4800 and the rpm range in between is not shown...will the truck use the values from the 3550rpm column all the way up until it hits the 4800 rpm column?
    Thanks!
    Peace Through Torque
    www.PunisherPerformance.com
    Jan 2008
    Yes the ECM will extrapolate the correct values based on the 3550 and the 4800 column.
  1. Question on a LBZ fuel rail pressure?
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 30th, 2009, 07:45 AM
  2. Question on Fuel System
    By Randy07GMAX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 17th, 2008, 06:13 PM
  3. AutoVE Commanded Fuel Question
    By SOMhaveit in forum General (Petrol, Gas, Ethanol)
    Last Post: October 10th, 2007, 12:35 AM
  4. Another dumb fuel pressure question.
    By ViolatorTA in forum Gen III V8 Specific
    Last Post: June 11th, 2007, 01:31 PM
  5. HELP! can't keep off the rev-limit/fuel-cut
    By white2001s10 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 27th, 2007, 01:16 PM
