I apologize ahead of time as I am inexperienced in the tuning world. In fact I have not tuned a car (yet). I am stubborn and will teach my self how to do so by countless hours of reading and question asking. I have done much reading on the forum and books I have purchased and developed a few questions. Some of the questions pertain to LSx motors. So please reply only if you have something productive to offer to this thread. I thank you for your help.
Welcome to the forum. The traits you have described are common to many tuners..especially the stubborn part..
1.) The basis of tuning is to make the engine breath more efficient? The better the burn, the better the explosion, the better the cylinder pressure?
Exactly. Thats why I like higher CR engines..
2.) Is there a general table or map you create when tuning and the software automatically adjusts and creates a new map?
Not as easy as you described..but with smoothing features etc., it can almost be done..
3.) In the Corvette, the MAF is directly after the large airbox. The MAF has a straight through design with no honey comb. Does this negatively effect MAF output? Is it beneficial to move it upstream?
Not sure of that exact answer. Some of us are not as anti-MAF as others. It is always a huge debate. I like the hybrid system..MAF and VE Table (blended). In any case, you do need a clean accurate MAF signal..
4.) Can you disable CAGS and enable fans to come on at earlier temps with EFI Live?
Absolutely!
5.) The addition of Headers is rumored to cause a lean mixture. Why is that? What would one do to correct that?
5.7ute's explanation is right on. I'll take the additional 15-25 HP/TQ and nice mellow sound..and just tune back to stoich AFR..
6.) What does the addition of a higher flowing CAI set-up do to the mixture?
If you can really get cooler denser air into engine..more HP/TQ. Sometimes though that additional air can create some turbulence with the MAF. That may relate to your previous question. The MAF can be re-calibrated appropriately though..
7.) Why can't the stock PCM tune compensate effectively for such mods?
Explained..
Sorry for all the questions. They are probably simple I just need to cover the basics before I can get more technical. Again thanks for the help.
Thats a good start. Just keep an open-mind though. Stubborn can be good..closed-minded might make tuning successfully a little more challenging..
