The Fuel Filte rminder is counting down at a rate of about 1% every 1/10th mile.... Anyone ever seen this happen? The relevant table in the tune is stock....
sounds like you get about 10 miles out of a fuel filter... that's gunna be spendy in the long run, maybe you should have bought a ford
J/k
That's really odd, and the minder table in the tune is stock? super weird! What about the FPR flow rate tables? stock?
Yeah, all stock. Only things I've changed is killed the IAH & EGR DTC's, vane tables to give it the "rumble" idle & turbo brake, and speedometer tables to correct the speedometer for my 265's.
just for shits and gigs, what if you change the speedo tables back to stock? whats the IAH?
I assume this is your LBZ?
Oh yeah the LLZ. i think that might be part of the problem too!
Well, I don't think that the LBZ swap is the issue... I swapped in another ECM and reset the FF minder, and it dropped to 99% somewhat quick, but in the 1 or 2 miles I drove it, didn't go any lower.... I'll drive it a bit more to confirm....
Edit: Now I'm pretty sure it's something in the ECM. I just put about 20 miles on it with the second ECM and it hasn't left 99%... Anyone have any thoughts? Could it be some remnant left over from the flashes with the APP voltages changed that borked the ECM?
have you full flashed back to 100% stock the first ECM to see if that fixes it?
Not yet.... That next tonight (Assuming the ECM survived it's fall.... TTM... Don't ask).... After the last few FUBARs I only did cal flashes which fixed the ECM and got it working... maybe something's still borked in there...
