Results 1 to 6 of 6
Thread: bbl cant load tunes to truck???
    Mar 2008
    Default bbl cant load tunes to truck???
    ok i downloaded all updates put sd and formatted it,i loaded all my tunes to the sd card via efilive exp but when i try to load it the truck it takes about 30 seconds and then tells me to turn ignition off for 15 seconds but the tune wont go through????
    my pcm is locked with a password and the v2 doesn't ask for the password could this be the problem??
    Hi BBSS,
    Do you have the latest software, builds 117 and 97 (which includes firmware 2.6.35)...?
    Do you have firmware 2.6.35 flashed into your V2...?
    I don't know if the locked PCM is the problem, let me ask Tech Support.
    Mar 2008
    i have firmware 2.06.35..........and bootblock 2.06.03
    Mar 2008
    ok yeah the locked pcm was the issue i unlocked it and it works flawlessly......so for future reference the pcm needs to be unlocked for the bb flashing to work ..............thanks joecar
    Ok, thanks for the feedback, glad you got it going...
    Yes, that is correct. The BBR/BBF routines do not unlock a controller that has been locked with a custom key. The option to supply a custom key during BBR/BBR will be added in a future release.
  1. Can you load a cal into a COS without an ECM?
    By onfire in forum Custom Operating Systems
    Last Post: July 13th, 2009, 02:09 AM
  2. Converting DSP2 tunes to DSP5 Tunes
    By BlkMax in forum Duramax LB7
    Last Post: March 6th, 2009, 10:14 AM
  3. C.O.S. will not load.
    By Webbs in forum Custom Operating Systems
    Last Post: October 2nd, 2008, 05:59 AM
  4. Would unlocked tunes encourage you to pay for more tunes?
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: November 11th, 2005, 01:09 PM
  5. Need help with a load vs. rpm vs. KR MAP!
    By Redline Motorsports in forum General
    Last Post: October 25th, 2005, 03:52 PM
