Results 1 to 2 of 2
Thread: Flash a 05 Corvette
    Jan 2008
    Default Flash a 05 Corvette
    I'll flash a 05 Corvette soon and want to know, if i have to do a full reflash
    to use the cos for E40 ? Do i've to remove some fuse to flash ? What 2.5 bar
    map sensor to use with this cos ?
    Thank's
    w/t1500
    Jan 2005
    When you switch to a custom operating system, you have to do a full reflash. Read the tutoria under the "Help" tab in the tuner-- it has everything you need to know. As for a 2.5-bar MAP sensor, I don't know of any. Use a GM 2-bar or 3-bar sensor as required by your boost levels.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
  1. Will E38 from 08 Corvette work in 2007 Corvette?
    By Chalky in forum Gen IV V8 Specific
    Last Post: June 5th, 2010, 10:00 AM
  2. Pre Full Flash to Full Flash Tune Question
    By Donovan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 13th, 2010, 12:43 PM
  3. New Corvette
    By 5.7ute in forum Lounge
    Last Post: June 29th, 2009, 05:19 PM
  4. '08 Corvette A6 Cal
    By gmh308 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: June 18th, 2008, 04:46 AM
  5. BCM relink and VIN flash? 97 corvette
    By mvvette97 in forum Gen III V8 Specific
    Last Post: November 2nd, 2007, 08:23 AM
