Originally Posted by
Blacky
Which trans?
That error occurs when EFILive detects that the calibration data in the PC's memory has been modified by something other than EFILive.
EFILive keeps multiple copies of the calibration in memory and whenever the EFILive software updates the calibration data it updates the copies as well. If any copy becomes different from the other(s) then this error is displayed. The only way for one copy to be different is if that copy was modified by some other application or bug/failure of EFILive or Windows or the PC hardware itself. Make sure you're using the latest update of the EFILive software (to eliminate the "bug in EFILive" possibility).
Has your PC been behaving strangely? Crashing or rebooting for no apparent reason? Applications freezing up or just terminating? Unexplained error messages? Features that sometimes don't work like copy/paste? Any of those symptoms could indicate some form of malicous code running on your PC. Or it could be a hardware/memory fault.
